RyanUeck01
Feb 05, 2017Follower
ReadyNAS NV+ RND 4000 relocating hard drives to Netgear RN21400-100NES
Good Day I had a ReadyNAS NV+ RND 4000, but it was struck by lightening and so the machine does not work anymore, I have had the hard drives tested and was told they are fine. My insurance is rep...
Feb 06, 2017Guru - Experienced User
RyanUeck01 wrote:
Good Day
I want to know will I be able to take my hard drives from my old Nas and put them into this new one be able to ready my data on them.
You can't just migrate the disks - they are formatted very differently.
There is way to offload the data with help from support. You will need enough storage to copy the data - this just gives you a way to mount the volume so it can be copied. http://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6?cid=wmt_netgear_organic
