gmhitchcock
Sep 29, 2014Aspirant
ReadyNAS NV+ (sparc) - OS Partition 100% - How to Fix
I've been unable to access NAS via Frontview. Can view shares and access via ssh. How do I clean up the OS?
login as: root
root@192.168.1.119's password:
Linux DelphiNAS 2.6.17.14ReadyNAS #1 Wed Jun 20 20:08:20 PDT 2012 padre unknown
DelphiNAS:/# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 2.0G 0 100% /
tmpfs 16k 0 16k 0% /USB
/dev/c/c 5.4T 2.4T 3.0T 43% /c
/c/GMH 5.4T 2.4T 3.0T 43% /home/ftp/GMH
/dev/sda1 1.8T 226G 1.5T 13% /USB/USB_HDD_1
/USB/USB_HDD_1 1.8T 226G 1.5T 13% /home/ftp/USB_HDD_1
login as: root
DelphiNAS:/# df -h
- mdgm-ntgrNETGEAR Employee RetiredI'd start by running commands such as these:
# cat /var/log/frontview/raidiator_version
# du -csh /var/*
# du -csh /var/log/*
# du -csh /var/log/frontview/*
You are looking for e.g. a large log file or something like that that is filling the OS partition. - gmhitchcockAspirantSee below:.... looks like /var/log/
DelphiNAS:~# du -csh /var/*
192k /var/backups
99M /var/cache
32k /var/ftpd
36M /var/lib
16k /var/local
32k /var/lock
1.3G /var/log
16k /var/mail
16k /var/netatalk
16k /var/opt
3.4M /var/run
544k /var/spool
16k /var/tmp
32k /var/www
48k /var/yp
1.5G total
DelphiNAS:~# du -csh /var/log/*
16k /var/log/auth.log
944k /var/log/cron.log
32k /var/log/cups
179M /var/log/daemon.log
16k /var/log/ddns
1.2M /var/log/debug
16k /var/log/dmesg
768k /var/log/exim
63M /var/log/frontview
10M /var/log/kern.log
16k /var/log/ksymoops
6.1M /var/log/LeafP2P.log
11M /var/log/messages
80k /var/log/mt-daapd.log.old
16k /var/log/ntpstats
16k /var/log/proftpd.log
1.3M /var/log/samba
16k /var/log/squeezecenter
186M /var/log/syslog
854M /var/log/upnp-av.log
800k /var/log/upnp-av.log.old
16k /var/log/user.log
1.3G total
What next? Remove the upnp-av.log? Any others? - mdgm-ntgrNETGEAR Employee Retiredupnp-av.log is the log for ReadyDLNA.
Rather than removing it, I would do
# echo "" > /var/log/upnp-av.log
/var/log/syslog and /var/log/daemon.log are also quite large. You may wish to copy those to the data volume (in case they contain something important) then empty them.
You may also wish to do e.g.
# tail -n 100 /var/log/syslog
to see if there are any important messages in the log.
What about
Could be some large log files in there. - mdgm-ntgrNETGEAR Employee RetiredAlso, once you are finished fixing this you may wish to update to 4.1.14-T6 which addresses ShellShock: http://www.readynas.com/forum/viewtopic.php?f=17&t=59222
- gmhitchcockAspirantPreformed each of the above.
DelphiNAS:/# df -h
/dev/hdc1 1.9G 817M 1.1G 42% /
cle
DelphiNAS:/# du -csh /var/log/frontview/*
64k /var/log/frontview/access.log
16k /var/log/frontview/apache-ssl.pid
43M /var/log/frontview/backup
16k /var/log/frontview/command.log
32k /var/log/frontview/disk_smart_2014_07_23.log
16k /var/log/frontview/ecounter_2014_05_25_1623.log
16k /var/log/frontview/enclosure.log
512k /var/log/frontview/error.log
16k /var/log/frontview/memory.log
16k /var/log/frontview/partitions_2014_07_23.log
16k /var/log/frontview/smart_errors_hdc
16k /var/log/frontview/smart_errors_hde
16k /var/log/frontview/smart_errors_hdg
16k /var/log/frontview/smart_errors_hdi
16k /var/log/frontview/ups.log
43M total
Still can't get Frontview access.... still get "contact support error message". - mdgm-ntgrNETGEAR Employee RetiredCan you try the commands mentioned here: http://www.readynas.com/forum/viewtopic.php?p=384618#p384618
You probably need to try restarting Frontview. - gmhitchcockAspirantSee below: Same error message from Frontview.
DelphiNAS:/# apache-ssl -f /etc/frontview/apache/httpd.conf -t && apache-ssl -f /etc/frontview/apache/httpd.conf -k restart
apache-ssl: Could not reliably determine the server's fully qualified domain name, using 192.168.1.119 for ServerName
Syntax OK
DelphiNAS:/# tail /var/log/frontview/error.log
Bad free() ignored (PERL_CORE) at /frontview/lib/get_handler.pm line 2.
[Mon Sep 29 06:26:30 2014] [notice] Apache/2.2.6 (Debian) mod_ssl/2.2.6 OpenSSL/0.9.8e DAV/2 PHP/5.2.0-8+etch9~bpo31+1 mod_apreq2-20051231/2.6.0 mod_perl/2.0.3 Perl/v5.8.8 configured -- resuming normal operations
[Mon Sep 29 18:29:05 2014] [error] [client 192.168.1.131] File does not exist: /frontview/ui/resource/html/images, referer: https://192.168.1.119/admin/
iconv: error while closing output file: No space left on device
[Mon Sep 29 21:35:39 2014] [notice] SIGHUP received. Attempting to restart
[Mon Sep 29 21:36:05 2014] [notice] Apache/2.2.6 (Debian) mod_ssl/2.2.6 OpenSSL/0.9.8e DAV/2 PHP/5.2.0-8+etch9~bpo31+1 mod_apreq2-20051231/2.6.0 mod_perl/2.0.3 Perl/v5.8.8 configured -- resuming normal operations - mdgm-ntgrNETGEAR Employee RetiredYou get the same error message when you attempt to open Frontview?
Have you tried rebooting your NAS?
Have you tried clearing your web browser cache (e.g. Temporary Internet Files in IE), closing your web browser, then reopening Frontview? - gmhitchcockAspirant1. Yes
2. No
3. cleared, no change.
Rebooted NAS, now can access Frontview. However, RAIDar 4.3.8 shows -- under the information icon and setup is greyed out.
Regarding 4.1.14-T6, I downloaded it, but it had no extension? Is this correct? - mdgm-ntgrNETGEAR Employee Retired
So maybe some files were corrupted when the OS partition was full.gmhitchcock wrote:
Yes, that's correct.
Install it via System > Update > Local in Frontview. If the checksum is not valid, the NAS will refuse to install it.
