forquare
Mar 01, 2015Aspirant
ReadyNAS NV+ (SPARC) Kernel Panic with Factory Settings
Good evening all, History and setup: I've had my NV+ for three or four years, in that time it have been kitted out with 2x Seagate 2TB hard drives and 2x Western Digital 2TB hard drives, the four ...
forquare
No, I did a quick check that I could partition and format them, then did a "Verify disk" under Disk Utility in OS X.
I'd be happy if it was a disk, being far cheaper to replace than the ReadyNAS, but I find it odd that the problem doesn't follow a particular disk around the bays…
I'll investigate the vender tools and test each disk.
