forquare
Mar 01, 2015Aspirant
ReadyNAS NV+ (SPARC) Kernel Panic with Factory Settings
Good evening all, History and setup: I've had my NV+ for three or four years, in that time it have been kitted out with 2x Seagate 2TB hard drives and 2x Western Digital 2TB hard drives, the four ...
vandermerwe
Mar 01, 2015Master
After your factory default you say the unit starts a resync. You say it is resyncing to disk 4, what do you mean?
If you factory default with 4 disks in and the volume starts to resync, all disks are involved and you should not receive messages about specific disks.
Are you saying the initial resync happens normally but then the nas wants to resync with disk 4 again? If this is the case it may be that disk 4 is dropping out of the array for some reason, perhaps a bad slot/sata connector.
I would still run full tests on all the disks first.
