forquare
Mar 01, 2015Aspirant
ReadyNAS NV+ (SPARC) Kernel Panic with Factory Settings
Good evening all, History and setup: I've had my NV+ for three or four years, in that time it have been kitted out with 2x Seagate 2TB hard drives and 2x Western Digital 2TB hard drives, the four ...
forquare
Mar 03, 2015Aspirant
The Factory Reset seems to take around half an hour, and during that time I cannot access the web GUI. When RAIDar tells me the ReadyNAS is accessible, I log in and disk 4 is resyncing.
After managing to borrow a Windows laptop from work (the vender tools don't seem to be available for OS X), I've plopped the first disk into an enclosure and hooked it up via USB (2.0). The first Seagate one failed with "6C9AC2A4" which translates to "Serial number not detected, SeaTools did fail the drive", but that was several hours into the "Long Generic" test. Plugging the second Seagate drive in also shows that it's unable to ready the serial number and firmware version, though I'm not sure if that is due to communications over USB?
The second Seagate drive is currently on it's "Long Generic" test, I'll test the WD ones after.
