forquare
Mar 01, 2015Aspirant
ReadyNAS NV+ (SPARC) Kernel Panic with Factory Settings
Good evening all, History and setup: I've had my NV+ for three or four years, in that time it have been kitted out with 2x Seagate 2TB hard drives and 2x Western Digital 2TB hard drives, the four ...
Mar 04, 2015Guru - Experienced User
I have used Seatools with USB. Though I have a laptop with eSATA, so I usually use that for diags. There are some restrictions (and getting the serial might be one).
The net here is that the first disk failed ("Seatools did fail the drive"), and it seems real because it happened several hours into the test. If you can read the SMART stats, that might be useful information.
