forquare
Mar 01, 2015Aspirant
ReadyNAS NV+ (SPARC) Kernel Panic with Factory Settings
Good evening all,
History and setup:
I've had my NV+ for three or four years, in that time it have been kitted out with 2x Seagate 2TB hard drives and 2x Western Digital 2TB hard drives, the four drive in one volume. In January I directly connected the ReadyNAS to the second NIC on my Mac Pro, then used it as storage for the iTunes library to be streamed (via the Mac Pro) to my Apple TV - I've had poor experience with trying to serve content to my TV (XBOX/Raspberry Pi) and I wanted to go down an 'all Apple' route. The content was already on the ReadyNAS, so it was just a case of setting iTunes to look at the share for its library and import everything. This all went according to plan and worked for a month or so.
Problems:
About a week ago I went to stream a movie to my Apple TV, it got about 5 seconds in and the stream stopped. The ReadyNAS looked fine, the display appeared normal, but I couldn't access the Web interface or get in via SSH - the power button didn't work, so a hard power off ensued. After it booted back up everything connected again, and I selected the same movie to stream and the same thing happened.
Looking in the logs it appeared to have an issue on channel "(??)", which is immensely helpful…All the disks looked OK, nothing specific was being reported. I tried a few hard reboots and occasionally got a Kernel Panic. I managed to get everything working by taking the second disk out (middle left), it was only a hunch that this would work due to some differing activity on the disk 2 LED. I've transfered all of my content elsewhere for the time being, and have spent bits of free time this week trying to troubleshoot.
I have performed a Factory Reset and although it reports the same sized volume, it says it must resync disk 4. When the resync had about 2% to go, it kernel panicked. Before this happened, I SSHd into the ReadyNAS to look around (nothing destructive). I was intrigued to find the volumes appear to be set up with LVM, and doing a quick `fdisk -l` found that disks 1-3 had a smattering of partitions, but disk 4 did not.
I have since taken all of the hard drives out of the ReadyNAS, hung them off of another computer, checked them, and wiped the partition tables clean - each disk looks 'new'. With the power off, installed the disks again in a different order, and on the first boot selected a Factory Reset. Again, the web GUI showed that it was resyncing to disk 4…Again, when it got to around 2% until complete, I got a Kernel Panic. Again, before it panicked I looked at the disks via SSH and disk 4 didn't have any partitions
I've checked the memory, and the ReadyNAS reports it to be OK…
In between times, I've found that the first three bays seem fine, just populating them seems to be OK. I haven't tried populating three bays where one is bay 4, though not sure if this adds anything…
It seems odd that the first three disks get partitioned, etc, on a Factory Reset, but the fourth disk doesn't appear to...
So now I'm at a bit of a loose end…The logs in the web interface seem to tell me nothing specific, in fact nothing at all aside from the fact that I pulled the power when it wasn't ready…
Linux, Solaris, throw it at me. Storage and networking, erm, not so good at!
Many thanks in advance,
Ben
History and setup:
Problems:
Ben
- forquareAspirantDownloaded. Will give it a go once this scan has completed :)
