Msquared-99
Sep 29, 2015Aspirant
ReadyNAS NV stuck on resync 40.1%
ReadyNas NV +2 inc 4 x 1tb Western Digital I received an email from the NV+2 to say disk 4 was having a few smart issues and I should considering changing it, I ordered a new drive idetical to othe...
mdgm-ntgr
Sep 29, 2015NETGEAR Employee Retired
You might have another failing disk.
Can you power down, remove your disks (label order), hook them up to your PC and test them using WD Data Lifeguard Diagnostics?
