invidianer
Aug 09, 2015Aspirant
ReadyNAS NV+ v1: Every username/password accepted while connecting via SMB
Hi everyone! If I press "cmd" and "k" on my Mac with OS X 10.10.4 to connect to my ReadyNAS NV+ v1 via SMB it accepts ANY username/password-combination! I set the admin-password via the web-fron...
invidianer
Oh ... where can I see that?
mdgm-ntgr
Aug 09, 2015NETGEAR Employee Retired
In Frontview go to Shares > Share Listing > Share name, select the CIFS protocol for the share and see if the "Allow guest access" checkbox is checked.
- invidianerAug 11, 2015Aspirant
Hmm, there is no checkbox for guest access :(
My Frontview looks like this:
- mdgm-ntgrAug 11, 2015NETGEAR Employee Retired
Under Security > Security Mode which mode are you using?
Share mode has long been EOL and I suspect that is what you are using.
Please see http://readynas.sphardy.com/2010/09/how-to-migrate-to-user-security-mode_4917.html
