TemplePO
Aug 22, 2020Aspirant
ReadyNAS NV+ v1 not booting, HD Lights 1 & 3 on - Cant find 4.1.16 USB Recovery
Hi all, I hope someone might be able to steer me in tthe right direction to help me sove my problem. Had a power cut after trying to restat the device the blue power light would flash rappidl...
- Sep 05, 2020
UPDATE: Problem solved
Befaor I started throwing miney at this issue, I remembered about the memory. I ordered a cheap replacement of Amazon and installed today. The box wakes up and is running as normal now. Next step is to look to migrate my data to a new location.
Thanks
TemplePO
Aug 31, 2020Aspirant
I appreciate that StephenB, I'll consider those options if I'm unable to get the USB option working.. I'm currently looking for a compatible usb drive at the moment.
Thanks again,
TemplePO
Sep 05, 2020Aspirant
Thanks
