JHock
Jul 30, 2017Aspirant
ReadyNAS NV+ v2 - connection refused
I have a ReadyNAS NV+ v2 (firmware 5.3.12) that I used a while back to offload family photos and other data. It seems that I did some sort of firmware upgrade and then I could see the system via Rada...
- Aug 09, 2017
The services configuration file was corrupt which would explain why services weren't starting.
JHock
Jul 31, 2017Aspirant
Hi Tony, thanks for the response. Admin account has been reset which is fine (on the new single disk). I don't even get to a logon screen as the logon page request has the connection request refused before even loading.
Windows 10 (But it was doing this on Windows 7 before my upgrade as well.) - Justin
Jul 31, 2017Guru - Experienced User
Just to clarify- the OS is on the hard disks. So whatever you did with the new single disk doesn't apply when you switch back to the old ones.
If you did the OS reinstall on the old disks, the admin password should have been reset to password there too.
If you didn't do the OS reinstall - is the IP address reported on the LCD screen compatible with your current network? (this is with your original disks running).
