JHock
Jul 30, 2017Aspirant
ReadyNAS NV+ v2 - connection refused
I have a ReadyNAS NV+ v2 (firmware 5.3.12) that I used a while back to offload family photos and other data. It seems that I did some sort of firmware upgrade and then I could see the system via Rada...
- Aug 09, 2017
The services configuration file was corrupt which would explain why services weren't starting.
Aug 08, 2017Guru - Experienced User
JHock wrote:
however that doesn't explain what happened to the original disks or why a raid 5 redundant system has a lock-out failure like this... if that's what a NAS will do, there's zero value in me having one.
I agree it doesn't explain what happened. On SMB it is a bit more complicated than usual right now, because Microsoft is changing SMB in the PCs.
FWIW, I haven't seen this particular combination of symptoms before ("connection refused" for the web admin UI, plus the SMB challenges). My own systems have never had the SMB problem. But I don't own any v2 NAS.
JHock wrote:
Where does one check the workgroup on the NAS device? It did work at one point in time and my pc hasn't changed from workgroup...
It depends on the NAS. See pages 69-70 here: http://www.downloads.netgear.com/files/GDC/READYNAS%20ARM-PLATFORM%20(DUO%20V2,%20NV+%20V2)/RAIDiator%205.3%20SW%20Manual_5Sep12.pdf
mdgm-ntgr
Aug 09, 2017NETGEAR Employee Retired
