smithy50
Jul 22, 2015Tutor
ReadyNAS NV+ V2 & Seagate 4TB ST4000VN000 HDDs
Hi, I have a ReadyNAS NV+ V2 installed with 2 x 2TB and 2 x 3TB HDDs from the Netgear HCL. I want to increase the capacity by replacing the 2x 2TB HDDs with 2 x 4TB HDDs. Does anyone know if ...
smithy50
Jul 23, 2015Tutor
Thanks StephenB for the quick response. I could not find any post that combined the ST4000VN000 and the NV+ V2 either.
It would be good if someone, who has tried the combination, could add to the thread.
Thanks Again
vandermerwe
Jul 23, 2015Master
Is your NAS still under warranty? If it is not then there is less concern about sticking to the HCL, it is dated as you can see. WD Red drives and the Seagate NAS drives are widely used on many Readynas models and it is exceedingly unlikely that you will have a problem. Of course no disks are perfect and you should always maintain backups.
