SASCHA_SCI
Nov 14, 2016Aspirant
ReadyNas NV+ v2 Booting & 'fault disk' problem - PLEASE HELP (8+ yrs of data/work at risk)
Dear Netgear Support, Dear Community, This is a desperate cry for help from a small business owner worried about potentially loosing 8+ years of work & critical business data. Please help in wha...
Nov 14, 2016Guru - Experienced User
Though Netgear paid support might be expensive, the potential data loss would likely be more expensive. I think your safest option is to allow escalation to level 2 or even level 3.
Unfortunately RAID is not enough to keep your data safe. Backups are still necessary. So after you get your data back (thinking positively :smileyhappy: ) you should put a backup plan in place for the NAS.
