jcharth
Dec 14, 2012Aspirant
ReadyNAS NV volume not resized after upgrade
Hello Everyon, I though I read in this forum that my volume would automatically increase size after replacing all 4 disks but it did not. This is the model of my old nas Model: ReadyNAS NV Firmwa...
mdgm-ntgr
Dec 14, 2012NETGEAR Employee Retired
Your firmware is very, very old. I would suggest you update to the latest firmware, backup your data and do a factory default (wipes all data, settings, everything), then restore data from backup.
NB: Before you update the firmware you should remove the ReadyNAS Photos and BitTorrent add-ons. These add-ons are EOL and no longer supported and no longer included in the firmware.
