MInDev
Mar 02, 2014Aspirant
ReadyNAS NV+ won't power on
Hello: about 6 months ago during an overnight thunderstorm I powered off my Netgear ReadyNAS NV+ (using Frontview -> Shutdown) and once it had switched off I disconnected it from its UPS and went back...
vandermerwe
Mar 01, 2015Master
Glad you sorted this out.
It is always better to start a new thread unless you have precisely the same problem and device as in an existing (and active) thread.
In your case it is probable that we would have suggested the CMOS reset procedure before you went for a new power supply - although it is certainly possible the power supply did need replacing.
