irrelevant
Aug 28, 2016Aspirant
ReadyNas NV+v2 no network connection
I've got an issue with a NV+ V2. All was working fine until yesterday, when I lost all network connectivity in the room with this in - After some diagnostics, I swapped out the switch that fed ev...
irrelevant
Aug 29, 2016Aspirant
OK... plugged the thing into a 10Mbps hub so I could monitor the network traffic from the laptop in case that gave mea a clue as to what was going on, and the **** thing suddenly became accessible for no readilly apparent reason.. Time to delve into the logs, I guess...
- BrianL2Aug 29, 2016NETGEAR Employee Retired
Hi irrelevant,
Well, you can try connecting the ReadyNAS directly to your PC, Router or another switch (supports 100/1000mbps). Also, tell us if the LAN link lights (LEDs) lit up. You may also want to try to perform OS reinstall and see if that helps. I doubt a USB ethernet adapter would work but you can give it a try and let us know what happens.
Kind regards,
BrianL
NETGEAR Community Team - BrianL2Sep 01, 2016NETGEAR Employee Retired
Hi irrelevant,
Just checking if you've tried what I've suggested on my last post. Keep this thread updated if you're able to resolve or still having issues with your ReadyNAS.
Kind regards,
BrianL
