sdww
Feb 26, 2024Aspirant
ReadyNAS NVX -- has some issues
I have a Model: ReadyNAS NVX Business Edition [X-RAID2] Firmware: RAIDiator 4.2.31 Memory: 1024 MB [6-6-6-24 DDR2] Volume C: Online, X-RAID2, 4 disks, 61% of 8237 GB used 5...
- Feb 29, 2024
After guidance from StephanB I've been able to access the device in Tech Support mode.
There was a large file in /var/log that was had / at 100%
I've truncated that file ReadyNAS_Remote.log as it didn't appear to have any valuable content.
Now I'm at 16% utilized.
Mounted the /c volume
Mounted an external 8TB USB drive with
mount -t ntfs /dev/sf2 /USB
and now am copying off data using
cd /c/media
find . -print | cpio -pdv /USB
I haven't started the NAS in normal mode yet as the cpio is taking a VERY long time.
I guess USB 2.0 speeds aren't that fast
Once I restart in normal mode I'll report back
Feb 26, 2024Guru - Experienced User
have you tried logging into frontview and then downloading the full log zip file?
sdww
It says the logs are empty, even though I did not empty them and there was a reboot entry prior to this problem starting
When I click on download all log files I get a page that says "Empty No Support" and
"This XML file does not appear to have any style information associated with it. The document tree is shown below."
