hypatia's avatar
hypatia
ReadyNAS NVX Power failure/apparent death
I have a 2010 bought ReadyNAS NVX which will no longer power up (not a flicker or glimmer of any life).  I have tried:
- changing cables
- changing power socket
- leaving cold for 24 hours and restarting
- tweaking the battery to reset it
After the above, as far as I can see the general experience is to replace the power supply.  However since a new power supply on Amazon or eBay is about  70 British pounds I would like to check out any other options or validating this is the issue.  Also I found instructions on the site for changing power supply on other models but not the NVX.
I do have at the moment a spare ATX 600W power supply - if I could connect this up it would let me at least prove its the power supply.  Wondering if this is supported or if it is likely to make things worse! http://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf
Alternatively, I do occasionally see second hand units - more money than a power supply but a full unit in case its actually the motherboard dead on mine.  I'm assuming any NVX case would do (eg that I could put my disks into a Pioneer edition case) but are they also cross compatible with the NV/NV+ range?
Finally, most of the data was backed up fortunately however my husband had just loaded on a bunch of files in the afternoon before the next backup ran.  Have readers had much success reading xraid-2 disks with native Linux systems or Linux Reader?
TIA
  • StephenB's avatar
    I fixed your link (the pinout url pointed to this post, not the pdf).
    The pinout diagram is NOT for the NVX - your NAS uses the standard pinout.
    Likely your ATX supply won't fit, but if you have long enough cables (or extender cables) you can run the ATX externally.
    This supply should work as a replacement: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151089  Though you might need some cable extenders/adapters (a short 24 pin extension and a sata->molex adapter are sometimes needed).
    • hypatia's avatar
      hypatia
      Thanks for correcting link and for the info - I also managed to post it twice (apologies, memory fail the next day when I thought I hadn't posted!).
      If the pin layout on the NVX is standard could I use my spare ATX PSU just to prove if the PSU is definitely the fault?  (its a Corsair CXM 600W  http://www.amazon.co.uk/dp/B00ALYOTTI )  If I could just prove it is definitely the PSU then I'd pay out the money for  the correct replacement which fits the unit - just afraid they if i go straight out and buy one it will be wasted if the mobo is dead.
      I do also have a ReadyNAS RNDP600U Ultra 6 Plus - both this and the NVX are on the same version of the firmware.  If I shut that down and removed the drives, swapping in the NVX drives could I start it up, copy off any files missing from the previous backup, then swap back in the Ultra 6 drives and carry on as normal?    I have been thinking about upgrading the NVX anyway so if I could just extract those files then instead of buying parts I could just go ahead with the new NAS.  Or is this likely to be more troublesome than successful?
      thanks
      • StephenB's avatar
        Yes, though its possible you'll need a 24 pin extender and/or a sata->molex adapter.
        That should also work.
ProSupport for Business
