cathcam
Sep 01, 2016Guide
ReadyNAS NVX rsync/duplication - Crossover Ethernet?
So I have two NVX NAS, identical drives, one primary, one backup. Both have two ethernet ports, only one from each NVX is attached to the same switch. Can I plug an ethernet cable in the spare eth...
Sep 01, 2016Guru - Experienced User
If you have a gigabit ethernet switch there is no real performance advantage in doing this - and it can create misbehaviors.
What you could alternatively do is try connecting both NICs on both NAS to the switch, and configure the two NAS to use NIC bonding - using the ALB method.
That might also misbehave, so if you see any issues the first thing to try is to disconnect one of the ethernet cables.
cathcam
Sep 01, 2016Guide
I figured it wouldn't be straight forward, although hoped.
I copied data between a couple of laptops this way with Windows many years ago, before USB existed, so figured it was worth asking. Yes, both have 1GB NICS and are attached to a switch that does 1GB. As you know from my earlier question, the primary is in the middle of a resync following a drive failure, once thats done I'll get this setup.
