Retired_Member
Jul 08, 2018ReadyNAS OS 6.9.3 fail (again)
I just updated from OS 6.9.2 to the latest OS 6.9.3 and found the NAS lost most of the Apps in the store (only 3 available apps in the store now?).
- GLPI (0.84.8+dfsg,1-1)
- PlexPy
-Shell in a...
- Retired_MemberJul 10, 2018
'apt-get upgrade' fixed the app store issue
Retired_Member
Jul 09, 2018I see over 500 packages listed most in ii status. I've msg'd u the list
mdgm-ntgr
Jul 09, 2018NETGEAR Employee Retired
ii readynasos 6.9.3 all ReadyNASOS base system
Looks like your NAS can’t download packages from the internet. That package should be at 6.9.3+3
If you set a static I.P. address on the NAS a common mistake is to notify specify any DNS Server Addresses.
- Retired_MemberJul 09, 2018
Not sure what you mean. I have a Static IP set (required) and have specified DNS server IP's (aren't these required for URL lookups)?
- StephenBJul 09, 2018Guru - Experienced User
Retired_Member wrote:
... and have specified DNS server IP's (aren't these required for URL lookups)?They are, but lots of folks setting static IP addresses forget to enter a DNS servers. mdgm-ntgr was just pointing that out.
Did you confirm internet connectivity, using ping or traceroute, and maybe host?
- mdgm-ntgrJul 09, 2018NETGEAR Employee Retired
If connectivity to the internet from the NAS is fine then packages in a broken state are stopping packages from being installed or some other problem. Looking further would require looking at other logs.
