andy-b
Jun 26, 2016Aspirant
ReadyNAS Pro 2 - no access
Hi, I have suddenly lost access to the data on my ReadyNAS Pro 2. I can log in via the Web admin interface, but all file sharing protocols are off and can not be turned on. The situation seems simi...
- Jun 26, 2016
Well, the original post was suggesting that you use the procedure here: http://onlyblueatwork.wordpress.com/2012/12/04/net
gear-readynas-access-recovery/ followed by mdgm's suggestions after you clean the OS partition
# cd
# sync
# umount /mnt
# mdadm --stop --scando you have a backup?
MikeFH
Hi Andy,
Seem's like is a common issue. I even lost acces to the admin GUI and the had to rebuild the OS.
Just for my santy, does you isue look like mine? Link here -> https://community.netgear.com/t5/Using-your-ReadyNAS/cannot-enable-any-readynas-services-in-netgear-readynas/m-p/1105663
Thanks
Mike
andy-b
Hi Mike,
Looks like you are using OS 6. I did not upgrade to that. So while the causes may be similar my issue looks different. I can not enable any protocols and the share list has disappeared.
/Andy
- MikeFHJun 26, 2016Aspirant
Thanks.
I am proper stuck ! here...
Looks like i need to back my data up and whipe my NAS and maybe format my disc
Mike
- StephenBJun 26, 2016Guru - Experienced User
andy-b, this thread might be helpful: https://community.netgear.com/t5/Legacy-NETGEAR-and-Partners-Add/Screwed-sshd-Service/td-p/878508
You could also get per-incident support from Netgear.
- andy-bJun 26, 2016Aspirant
StephenB,
this looks promising but when I try to install Enable Root SSH Access from http://kb.netgear.com/app/answers/detail/a_id/24551
I get "Update file is not valid for this architecture."
Is this the right one or this a misleading error message?
/Andy
