rookeydooks
Jun 04, 2014Aspirant
ReadyNAS Pro 2 Can't Access C:\ Drive
I've been running 2 x ReadyNas Pro 2's for a couple of years now with replicate between them. I had 2 file shares called: backup media Both can be access via explorer. For somereason repl...
rookeydooks
Hi Stephen, many thanks for your quick reply.
I checked credentials manager and there was no entry for the Nas, so i created 2 new ones under Control Panel\Windows Credentails using
In the box marked Internet or network address:
Ip Address >> 10.0.3.21
Username >> pro\admin
Password >> test
I also created a second credential for the Nas Name >> Listen2, with exactly the same username and password.
When i open windows explorer it now brings up a windows log in box with username already populated with pro\admin
I try the password i set = test
But it doesn't like it and just keeps asking me for the password over and over.
Password >> test
