rookeydooks
Jun 04, 2014Aspirant
ReadyNAS Pro 2 Can't Access C:\ Drive
I've been running 2 x ReadyNas Pro 2's for a couple of years now with replicate between them. I had 2 file shares called: backup media Both can be access via explorer. For somereason repl...
Jun 04, 2014Guru - Experienced User
There's a small typo in my earlier post. The user name should have been listen2\admin for the name, and 10.0.3.21\admin for the IP. You should probably edit it, but that shouldn't be crucial.
What firmware are you running? Is the NAS set up with user security mode or share security mode?
