rookeydooks
Jun 04, 2014Aspirant
ReadyNAS Pro 2 Can't Access C:\ Drive
I've been running 2 x ReadyNas Pro 2's for a couple of years now with replicate between them. I had 2 file shares called: backup media Both can be access via explorer. For somereason repl...
rookeydooks
Jun 05, 2014Aspirant
I've added 2 x new windows credentials for Nas name and IP but still doesn't like it.
Firmware is: RAIDiator 4.2.19
On Security Mode its enabled for User.
User. Fit for medium-size office or workgroup. Select this option if you would like to control access to shares based on user or group accounts and your network does not utilize a domain controller for authentication. If you select this option, you will need to create a user account for anyone accessing this device. This option supports setting disk quotas on a per-user or per-group basis.
Workgroup: Volume
The second choosable option is domain:
Domain. Fit for department or corporate environment. Select this option if you would like to control access to shares based on user and group accounts and your Windows network utilizes a centralized domain controller or active directory service (ADS) for login authentication. This option will not support disk quotas. Do not select this option if you are unsure.
Workgroup: Volume
