rookeydooks
Jun 04, 2014Aspirant
ReadyNAS Pro 2 Can't Access C:\ Drive
I've been running 2 x ReadyNas Pro 2's for a couple of years now with replicate between them. I had 2 file shares called: backup media Both can be access via explorer. For somereason repl...
rookeydooks
Jun 05, 2014Aspirant
Hi Stephen,
I have now updated the firmware on both boxes to:
Firmware: RAIDiator 4.2.2
When i went in to Shares/Share Listing on Frontview my June2012 folder now appears. I copied the CIFS and APS settings from the other 2 sahres, back/media and can now access the June201 share via Windows Explorer.
Inside the June2012 share there is a folder called: DMHIPK~Q. Inside that are the two back up folders form yesterday and today.
2014-06-04 00-00
2014-06-05 00-00
Inside the folders it shows as empty but if access the shares via https://replicate.readynas.com i can see all the backed up files in both 2014-06-04 00-00/2014-06-05 00-00 folders .
I added the 2 x new windows credentials: listen2\admin for the name, and 10.0.3.21\admin for the IP but its still wont let me log in.
2014-06-04 00-00
2014-06-05 00-00
