rookeydooks
Jun 04, 2014Aspirant
ReadyNAS Pro 2 Can't Access C:\ Drive
I've been running 2 x ReadyNas Pro 2's for a couple of years now with replicate between them. I had 2 file shares called: backup media Both can be access via explorer. For somereason repl...
rookeydooks
Jun 05, 2014Aspirant
Sorry, you are correct i did miss off a digit. The firmware is now RAIDiator 4.2.26
Anyway, we have progress! Using the net use command has worked to connect but i still can't see the backed up files.
I was already using z:\ so changed the command to n:\, so now if i open the N:\ drive from My computer i see the following folders/files:
backup
home
June2014
lost+found
media
aquota.group
aquota.user
Before i could only see the 3 shares.. backup/media/June2012.
If i drill down the home directory it has the following
home
>> admin
>>>> (This folder is empty)
Same for wher my backuo are in June2014
June2014
>> DMHIPK~Q
>>>> 2014-06-05 00-00
Its as if the files that are in there are hidden ?
backup
home
June2014
lost+found
media
aquota.group
aquota.user
home
>> admin
June2014
>> DMHIPK~Q
>>>> 2014-06-05 00-00
