rookeydooks
Jun 04, 2014Aspirant
ReadyNAS Pro 2 Can't Access C:\ Drive
I've been running 2 x ReadyNas Pro 2's for a couple of years now with replicate between them. I had 2 file shares called: backup media Both can be access via explorer. For somereason repl...
Jun 05, 2014Guru - Experienced User
Try setting the folder options so you can see hidden and protected operating system files.
(Open "folder options" in the control panel, then click on the "View" tab).
Put the defaults back when you are done (at least the system file setting).
I don't use replicate myself, so if that doesn't help find the files you may need another user to chime in.
