rookeydooks
Jun 04, 2014Aspirant
ReadyNAS Pro 2 Can't Access C:\ Drive
I've been running 2 x ReadyNas Pro 2's for a couple of years now with replicate between them. I had 2 file shares called: backup media Both can be access via explorer. For somereason repl...
rookeydooks
Jun 06, 2014Aspirant
Hi Stephen, i tried unhidding folders and files but no joy.
It is weird they way the files are all hidden. On the N:\ Drive i created and connected to it shows 613gb free of 913gb (in My Computer) so windows definetly knows the files are there. But when i open the N:\ drive and highlight all the folders and files in there, then select properties it shows size 14kb.
Will keep digging and report back if i ever find a solution. Maybe the only way to see these files is through the replicate portal?
Many thanks for all your help on this.
