rookeydooks
Jun 04, 2014Aspirant
ReadyNAS Pro 2 Can't Access C:\ Drive
I've been running 2 x ReadyNas Pro 2's for a couple of years now with replicate between them. I had 2 file shares called: backup media Both can be access via explorer. For somereason repl...
Jun 06, 2014Guru - Experienced User
Does the space show up in Frontview?
If you are still under warranty (5 years) then contact support at support.netgear.com.
If not, then I'd definitely install ssh and see if I could find the space that way.
