snowman50
Feb 24, 2020Aspirant
ReadyNAS Pro 4 - Visible in RaidAR, but can't load admin page
I've had a ReadyNAS Pro 4 for some years and had no issues, but now, although it's visible via RaidAR, I cannot access the Admin page, either through RaidAR OR directly through the network address (n...
Marc_V
Feb 24, 2020NETGEAR Employee Retired
Welcome to the Community!
Have you checked the IP address that the computer has? or have you tried other computers on your Network?
If you have changed your Network address it is possible that the IP addresses were not refreshed or renewed and a reboot or release might be needed.
HTH
Regards
- snowman50Feb 24, 2020Aspirant
I'm using the IP address on the front of the ReadyNAS, which matches that shown in RaidAR.
Any other suggestions?
Cheers.
Mark
- StephenBFeb 24, 2020Guru - Experienced User
Yes.
But that will only work if that IP address is on your subnet. For example, if the address is 192.168.168.168, and your router assigns IP addresses 192.168.0.x or 192.168.1.x, then you won't be able to connect with that address.
These IP addresses are safe to post (they are local, and can't be used to reach your NAS over the internet). Perhaps post the IP address of your PC and what you see on the NAS LCD screen.
OK.
PC is 192.168.0.49, NAS in 192.168.0.18, so I guess that's acceptable?
Thanks.
Mark
