Pro_s
Dec 03, 2017Aspirant
Readynas Pro 6 - Err Used disks Check RAIDar
I have a ReadyNAS Pro Pioneer edition with six 2TB disks running OS6 that now displays "ERR: Used disks Check RAIDar" when booting. This problem occurred recently when i swith it on after s...
- Dec 04, 2017
If it were my system, I'd test the disks with vendor tools in a windows PC (seatools for seagate, lifeguard for western digital). Replace any that fail (or which have more than 50 reallocated+pending sectors).
Then do a factory reset with all disks in place. Reconfigure the NAS and restore the data from the backup.
Pro_s
Dec 04, 2017Aspirant
Thank you for answer.
I have try to make OS Reinstall, device reboot and stuck at "Booting... Checking root FS" (more then 1 hour).
bedlam1
Dec 04, 2017Prodigy
I had a similar experience yesterday with my Pro 4.
Powering down the NAS and using Reinstall OS from the Boot Menu again then worked successfully
