stubbsy1
Oct 11, 2014Guide
Readynas Pro 6 - no display, How to factory reset?
I have a ReadyNas Pro 6. Some time ago the display stopped working (pressing the backup button does nothing, nor does it display during boot). Up until now this hasn't been a big deal, but now I want to factory reset it to move past the 16Tb limit (I have 6 x 4 Tb drives in it). Data is backed up, but I need to use the backup button to move through the menu shown on the display. Doing it blind would be OK if I knew what the menus looked like. I also have a Pro Business edition (so near identical) which is my backup to the 6. Could I safely step through the menu on the business and mirror the steps blind on the 6 without screwing up the business (don't want to factory reset it)? The best a search has yielded for me is http://www.readynas.com/forum/viewtopic.php?f=7&t=71844 where someone else has the same issue, but there is no workaround shown.
Better - is there some other way eg using Raidar to achieve what I want. Thanks in advance for any help :-)
- vandermerweMasterYour pro 6 should be under warranty , have you contacted support?
I think your plan to use the boot menu on the working unit to guide you should work. - mdgm-ntgrNETGEAR Employee RetiredLooks like two of the three Pro units registered to stubbsy are still under the 5 year limited hardware warranty if the dates shown on the support site are accurate.
One unit was purchased in early 2009 and is out of warranty. - stubbsy1Guide
mdgm wrote: Looks like two of the three Pro units registered to stubbsy are still under the 5 year limited hardware warranty if the dates shown on the support site are accurate.
Correct. Guess which one has the dead display :(
I thought I'd update this as well with some results:
1. I connected via frontView and went to System/Update/Factory Defaults (thanks mdgm for pointing out something obvious I missed) which did what was required
2. Then I tried another idea that occurred to me - swapped all the disks out of my working 6 (labelled each one) then put in the 6 disks from the one with dead display. Factory defaulted there then swapped all disks back in both boxes. That also seemed to work
4. Finally I also tried the approach of mirroring what I did on my Pro Business with a working display - that also worked without issue
Yes that's doing the same thing three times - I was curious. All is now working fine. - MoRaXAspirant
HI,
same exact problem. Were you able to solve it?
I know it's been a long time but I want to try to ask for info anyway....Thank you
