NetWhiz
May 26, 2025Guide
ReadyNAS Pro 6 - Stuck on booting while checking fs
I have searched for similar errrors on here, but none seem to either work or be related as to my situation. My Pro 6 just started to freeze a couple days ago while it was running. I had updated i...
May 27, 2025Guru - Experienced User
NetWhiz wrote:My Pro 6 just started to freeze a couple days ago while it was running. I had updated it to OS6 a long while ago. Thinking it might just be a random error, I restarted the device and now it gets to the checking root fs and stops around half way (sometimes more or less). I have tried the following:
Did you upgrade the RAM, or is it still using the default 1 GB?
Did you try using the boot option that skips the FS check?
How full is the OS partition?
NetWhiz
May 27, 2025Guide
NO, still using the default RAM.
Yes, I did try the FS Skip but it still hangs during the Root FS check stage.
Running the following:
# mount --bind / /mnt
# du -d1 -h /mnt
4.0K /mnt/tmp
0 /mnt/sysroot
0 /mnt/sys
8.0K /mnt/run
0 /mnt/proc
0 /mnt/opt
0 /mnt/mnt
0 /mnt/media
0 /mnt/home
52.0K /mnt/var
9.5M /mnt/usr
396.0K /mnt/sbin
2.6M /mnt/lib
2.4M /mnt/etc
420.0K /mnt/bin
16.0K /mnt/root
0 /mnt/dev
15.5M /mnt
- StephenBMay 27, 2025Guru - Experienced User
Some have found that isn't enough, so I now recommend upgrading to between 2 GB and 4GB. That is still inexpensive. 8 GB is possible, but expensive and it is hard to find 4 GB memory sticks that are compatible.
NetWhiz wrote:
15.5M /mnt
Looks like you are running the boot OS and not the OS partition (that is, you ran start_raids instead of rnutil chroot). The OS is much larger than 15.5M.
You could try mount /dev/md0 /mnt
if that works you could try checking it from ssh.
- NetWhizMay 27, 2025Guide
I was running the check as you outlined here: RN314 - OS partition full? | NETGEAR Communities to be preemptive in your possible next steps.
I had not ran start_raids at the time, just the commands from your reply.
Here is what I get when I run rnutil chroot:
# rnutil chroot root@2H0523RC00354:/# df -h Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 1.4G 2.4G 37% / udev 10M 0 10M 0% /dev tmpfs 495M 0 495M 0% /run- StephenBMay 27, 2025Guru - Experienced User
That was for someone running the NAS normally (and connecting with ssh). Not for tech support mode.
It looks like the OS partition mounts normally. I guess there could still be an error on the OS though. You could try running btrfs check / to see. That is safe as long you don't attempt a repair (with --repair).
The error is more likely with the data volume. Are you using XRAID? Can you post the output of lsblk ?
I just ordered a couple 2 GB DIMMs.
