NetWhiz
May 26, 2025Guide
ReadyNAS Pro 6 - Stuck on booting while checking fs
I have searched for similar errrors on here, but none seem to either work or be related as to my situation. My Pro 6 just started to freeze a couple days ago while it was running. I had updated i...
NetWhiz
May 27, 2025Guide
NO, still using the default RAM.
Yes, I did try the FS Skip but it still hangs during the Root FS check stage.
Running the following:
# mount --bind / /mnt
# du -d1 -h /mnt
4.0K /mnt/tmp
0 /mnt/sysroot
0 /mnt/sys
8.0K /mnt/run
0 /mnt/proc
0 /mnt/opt
0 /mnt/mnt
0 /mnt/media
0 /mnt/home
52.0K /mnt/var
9.5M /mnt/usr
396.0K /mnt/sbin
2.6M /mnt/lib
2.4M /mnt/etc
420.0K /mnt/bin
16.0K /mnt/root
0 /mnt/dev
15.5M /mnt
May 27, 2025Guru - Experienced User
NetWhiz wrote:NO, still using the default RAM.
Some have found that isn't enough, so I now recommend upgrading to between 2 GB and 4GB. That is still inexpensive. 8 GB is possible, but expensive and it is hard to find 4 GB memory sticks that are compatible.
NetWhiz wrote:15.5M /mnt
Looks like you are running the boot OS and not the OS partition (that is, you ran start_raids instead of rnutil chroot). The OS is much larger than 15.5M.
You could try mount /dev/md0 /mnt
if that works you could try checking it from ssh.
- NetWhizMay 27, 2025Guide
I was running the check as you outlined here: RN314 - OS partition full? | NETGEAR Communities to be preemptive in your possible next steps.
I had not ran start_raids at the time, just the commands from your reply.
Here is what I get when I run rnutil chroot:
# rnutil chroot root@2H0523RC00354:/# df -h Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 1.4G 2.4G 37% / udev 10M 0 10M 0% /dev tmpfs 495M 0 495M 0% /run- StephenBMay 27, 2025Guru - Experienced User
That was for someone running the NAS normally (and connecting with ssh). Not for tech support mode.
It looks like the OS partition mounts normally. I guess there could still be an error on the OS though. You could try running btrfs check / to see. That is safe as long you don't attempt a repair (with --repair).
The error is more likely with the data volume. Are you using XRAID? Can you post the output of lsblk ?
root@2H0523RC00354:/# btrfs check / ERROR: not a regular file or block device: / ERROR: cannot open file system root@2H0523RC00354:/# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 2.7T 0 disk |-sda1 8:1 0 4G 0 part | `-md0 9:0 0 4G 0 raid1 /mnt |-sda2 8:2 0 512M 0 part | `-md1 9:1 0 511.4M 0 raid1 `-sda3 8:3 0 2.7T 0 part `-md127 9:127 0 13.6T 0 raid5 sdb 8:16 0 2.7T 0 disk |-sdb1 8:17 0 4G 0 part | `-md0 9:0 0 4G 0 raid1 /mnt |-sdb2 8:18 0 512M 0 part | `-md1 9:1 0 511.4M 0 raid1 `-sdb3 8:19 0 2.7T 0 part sdc 8:32 0 2.7T 0 disk |-sdc1 8:33 0 4G 0 part | `-md0 9:0 0 4G 0 raid1 /mnt |-sdc2 8:34 0 512M 0 part `-sdc3 8:35 0 2.7T 0 part `-md127 9:127 0 13.6T 0 raid5 sdd 8:48 0 2.7T 0 disk |-sdd1 8:49 0 4G 0 part | `-md0 9:0 0 4G 0 raid1 /mnt |-sdd2 8:50 0 512M 0 part `-sdd3 8:51 0 2.7T 0 part `-md127 9:127 0 13.6T 0 raid5 sde 8:64 0 2.7T 0 disk |-sde1 8:65 0 4G 0 part | `-md0 9:0 0 4G 0 raid1 /mnt |-sde2 8:66 0 512M 0 part `-sde3 8:67 0 2.7T 0 part `-md127 9:127 0 13.6T 0 raid5 sdf 8:80 0 2.7T 0 disk |-sdf1 8:81 0 4G 0 part | `-md0 9:0 0 4G 0 raid1 /mnt |-sdf2 8:82 0 512M 0 part `-sdf3 8:83 0 2.7T 0 part `-md127 9:127 0 13.6T 0 raid5 sdg 8:96 1 122.5M 0 disk `-sdg1 8:97 1 122.4M 0 part
# rnutil chroot root@2H0523RC00354:/# df -h Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 1.4G 2.4G 37% / udev 10M 0 10M 0% /dev tmpfs 495M 0 495M 0% /run root@2H0523RC00354:/# ^C root@2H0523RC00354:/# du -d1 -h /mnt 0 /mnt root@2H0523RC00354:/# mount --bind / /mnt root@2H0523RC00354:/# du -d1 -h /mnt 6.6M /mnt/bin 0 /mnt/boot 24K /mnt/dev 5.6M /mnt/etc 33M /mnt/lib 4.0K /mnt/lib64 0 /mnt/media 4.2M /mnt/opt 0 /mnt/proc 82M /mnt/root 0 /mnt/run 11M /mnt/sbin 0 /mnt/srv 0 /mnt/sys 0 /mnt/tmp 524M /mnt/usr 605M /mnt/var 0 /mnt/mnt 0 /mnt/apps 0 /mnt/home 0 /mnt/Data 1.3M /mnt/preinstall-dpkg 30M /mnt/frontview 1.3G /mnt
I just ordered a couple 2 GB DIMMs.
