NetWhiz
May 26, 2025Guide
ReadyNAS Pro 6 - Stuck on booting while checking fs
I have searched for similar errrors on here, but none seem to either work or be related as to my situation. My Pro 6 just started to freeze a couple days ago while it was running. I had updated i...
NetWhiz
May 28, 2025Guide
It does mount. However, how do i get it off to another drive since I can only boot into Tech Support mode? I have an enclosure with 13.5 TB free but it is eSATA only.
Is there a way to get the unit to boot w/o trying to do anything with the /dev/md127 volume so I can then mount it in readonly and copy the data off across teh network?
NetWhiz
May 28, 2025Guide
The root fs check is where it is hanging. Can you (or someone rebuild that partition like mdgm / mdgm-ntgr) so it boots back up? I can then grab the data off it and then reset the NAS to factory and recreate the volume again (obviously).
