Pete_C
Feb 07, 2016Tutor
ReadyNAS Pro 6 Checking root FS
Hi, I have a small issue with my ReadyNAS Pro 6 running OS6.4.0. Until recently it has been runnning fine. However, when the unit was booted up yesterday it shows the squares for each of the six...
- Feb 09, 2016
It's all,sorted with huge thanks to mdgm who has reinstalled the OS on the unit.
masammut
Mar 17, 2016Aspirant
Ok - So removing and replacing ethernet cables and a couple of reboots and both NICs are being detected and so a new LACP bond was created successfully.
However all of sudden now, the system fan is at 0 RPM and an error is naturally coming up every couple of minutes. I'm not sure if the system is overheating, but something is not right. Any ideas?
Also the Status is saying that the "System is Dead" maybe could be related to the System fan though.
masammut
System Fan issue also solved by moving the system fan cable to the unused connector on the IO card.
System is Healthy now and working perfectly - thanks especially to mdgm who took the time to remote into my system to fix the Root FS issue.
- mdgm-ntgrMar 17, 2016NETGEAR Employee Retired
Great. If all is now resolved you can now mark a post as the solution.
- masammutMar 17, 2016Aspirant
mdgm wrote:Great. If all is now resolved you can now mark a post as the solution.
Trying to figure out how to do that...
- mdgm-ntgrMar 18, 2016NETGEAR Employee Retired
You should see an "Accept as Solution" button below each post (apart from the opening post in the thread).
