RJBeggs
Oct 12, 2012Aspirant
ReadyNAS Pro 6 Disk space not increasing after expansion
Had 6 x 2TB drives installed. Removed one, replaced with a 3TB, rebuilt. Removed another 2TB, replaced with a 3TB and rebuilt. No change. Replaced and rebuilt one more time (now 3 x 2TB, 3 x 3TB). ...
Oct 12, 2012Guru - Experienced User
There is an 8 TB expansion limit (meaning that the volume cannot be expanded more than 8 TB from the the starting point). Do you recall how many disks were in place when you installed (or at the last factory default).
Also, what firmware is running on the Pro?
