dhl
Oct 15, 2017Luminary
ReadyNAS Pro 6 Inactive Volumes - Main Volume Gone
Yesterday our ReadyNAS Pro 6 running firmware version 6.8.1 became inaccessable and upon reboot, shows the main voulume missing: This problem occured without any error warnings before...
dhl
Oct 17, 2017Luminary
Bumping this topic - we're working with local files pulled from the backup but really need help.
mdgm-ntgr, StephenB - any advice?
Thanks!
--dhl
Oct 17, 2017Guru - Experienced User
Unfortunately it's not something I can help with. Hopefully someone from Netgear will reach out to you and at least check your logs.
