lutinplunder
Jun 27, 2018Tutor
ReadyNAS pro 6 on 6.9.3 freezing after boot
I am having a problem with my readyNAS freezing shortly after boot, can not acces it with Raidar, WebGUI or SSH. if I pull all the drives boots fine and can access it with WebGUI & SSH.I tried doing ...
lutinplunder
Jun 30, 2018Tutor
I ran WD Data LifeGuard and all drives pass the SMART and quick tests
Jun 30, 2018Guru - Experienced User
Did you check OS partition fullness with ssh (df -h)? Use df -i to check inode usage as well.
- lutinplunderJul 01, 2018Tutor
I was able to get in with SSH once fast enough before the NAS froze and OS fullness was aroung 46%. Really scratching my head on what the issue is maybe an app is locking it up, is there anyway to disable them without frontview/SSH access?
- StephenBJul 01, 2018Guru - Experienced User
46% is fuller than usual, but not dangerously full. What apps do you have installed?
- lutinplunderJul 03, 2018Tutor
I managed to turn off everything but PHP, PHPMyAdmin and Python. Otherwise I have MySQLServer, SickRage, CouchPotato. SABNzb, Transmission, and a few others installed (but I don't use the unlisted ones often).
- Jan 17, 2024Retired_Member
- Jul 08, 2018Retired_Member
