WingDog
Apr 08, 2018Guide
ReadyNAS pro 6, random halt after 6.9.0
Hello. After FW upgrade to 6.9.0 one of the Pro6 boxes started to halting at random time. No ping, no web interface, no iSCSI, no SMB. upgrading to 6.9.3 didn't help. how to fix it? thanks.
Retired_Member
Apr 09, 2018At the given times it might be totally overwhelmed by dealing with the antivirus service. If not already done, you might want to disable this and see whether it helps.
Another resource hog is is the file search service. You might want to try switching this off, too.
