WingDog
Apr 08, 2018Guide
ReadyNAS pro 6, random halt after 6.9.0
Hello. After FW upgrade to 6.9.0 one of the Pro6 boxes started to halting at random time. No ping, no web interface, no iSCSI, no SMB. upgrading to 6.9.3 didn't help. how to fix it? thanks.
mdgm-ntgr
Apr 09, 2018NETGEAR Employee Retired
Are you running any other services?
Are you using any apps?
Can you send me your logs (see the Sending Logs link in my sig)?
WingDog
Apr 09, 2018Guide
I sent log to you.
Search and AV are disabled.
Services are only: http/https/snmp/ssh (it's storage for iSCSI LUN only).
no any apps installed.
- mdgm-ntgrApr 09, 2018NETGEAR Employee Retired
Your logs are flooded with messages about iSCSI.
How big was the LUN you created? Was it thick/thin?
Is your backup up to date?
