lutinplunder
Oct 18, 2015Tutor
ReadyNAS Pro 6 (RNDP6350) VPD issue?
My ReadyNAS isn't showing properly in raidar and frontview is broken (doesn't seem to load completely) Please HELP! I have tried pulling my 12TB media array and replaced it with a bla...
- Oct 20, 2015
Can you access the boot menu and set your NAS to tech support mode? You should then see a 5 digit number on the LCD panel and in RAIDar. Please send me a PM with that 5 digit number and I will take a look to see if I might be able to help.
BrendanM
Oct 20, 2015NETGEAR Expert
- lutinplunderOct 22, 2015Tutor
Thank you so much Brendan after you fixed the vpd issue i was able to power down reinsert my 13TB array and it came up just fine.
- shino1234Oct 29, 2015Aspirant
I use ReadyNAS Pro 2 and have same problem...
I contacted Netgear Japan support last week, but they haven't reply yet.
Please help me !
