IanSav
Nov 16, 2021Apprentice
ReadyNAS Pro 6 running OS 6.10.5 Hotfix 1 - AntiVirus not updating
ReadyNAS Pro 6 running OS 6.10.5 Hotfix 1 has stopped updating the AntiVirus software. I am being sent the following Email messages from the NAS: Antivirus scanner definition file update failed ...
- Nov 16, 2021
IanSav wrote:
Does it support this model of ReadyNAS (it is not in the list of supported devices).
Netgear doesn't support OS-6 on your Pro 6 at all. You should have been aware of that when you converted it from 4.2.x. However, OS-6 (and this release) will work on the Pro-6. FWIW, my own Pro 6 is converted.
BTW, if you are using the stock memory (1 GB) on your Pro-6, then I suggest that you upgrade it to 2 GB (or perhaps 4). This is easy to do, and inexpensive. Some folks have run into out-of-memory conditions (typically crashes) with the stock memory.
IanSav wrote:
My belief was that the code would become an online update when it was fully tested and ready for production use.
This isn't beta, Netgear has released it for production. But Netgear always releases firmware for manual installation first, and then afterwards puts it on the update servers (generally one to two weeks later).
If you are willing to wait, then just check every day or so. But if the AV is important to you, you can manually install it.
Nov 16, 2021Guru - Experienced User
IanSav wrote:
My question is when will this update be made available for normal online update for the ReadyNAS Pro 6?
Hard to say. If this is important for you, just install the x86 img file manually from https://kb.netgear.com/000064345/ReadyNAS-OS-6-Software-Version-6-10-6.
IanSav
Is that code production ready? Does it support this model of ReadyNAS (it is not in the list of supported devices).
- StephenBNov 16, 2021Guru - Experienced User
- IanSavNov 16, 2021Apprentice
Thanks for the extra information.
I have been checking for updates but none were shown. I had expected the update to be shortly after the code was posted, I will give it a bit more time. If there is nothing in another week or so I will go for the manual update.
Thanks for the personal reassurance of the update on your own ReadyNAS Pro 6.
My ReadyNAS Pro 6 has 4GB of RAM. ;)
- IanSavNov 20, 2021Apprentice
The online update appeared yesterday. AntiVirus updated successfully.
