SteveMathews
Nov 20, 2016Guide
ReadyNAS Pro 6 stuck at Booting...
Help!
For a few days now my Pro 6 has been hanging on the boot screen at about 5% complete.
Prior to this it has been stable for the last 3 months and hapily uploading/ synchronising to the Amazon Cloud. I expect the problem is tha the log files have swamped the partition but i can't confirm this and and i'm not sure how to proceeed!
can anyone help?
thanks
Steve
SteveMathews wrote:
if these are any help
Not really, ls -i shows the inode for each file, but it doesn't give you the number of inodes used.
If you use dlna, then go into /var/cache and delete the contents of the dlna cache folder.
Then perhaps just try booting again.
