rjwerth
Oct 28, 2015Luminary
ReadyNAS Pro 6 with 6.4 reporting a status of "Dead"
As the subject says, since putting 6.4 on, the system status is "Dead." Oddly enough, everything seems to be fine except the case fan is not running very much. Temps seem fine so that might be a fe...
- Dec 12, 2015
Thanks for the info, this fixed the issue. I opened up my ReadyNAS Pro 6 and moved the System FAN connector to the unused slot, and the FAN doesn't stop anymore (and I no longer get FAN warnings/errors).
In Step 2 on the page below you can see the slot circled in.
rjwerth
Nov 03, 2015Luminary
It seems like a number of people are having the issue since 6.4 who hadn't before. I know historically there have been issues with 6.x and fans from legecy boxes, but I've never had that problem until now. I also didn't see any good solution...did I miss something? Also, everyone else seems to have the error on their CPU fan. Mine is on the case fan. Strange!
Thanks.
ATCIS
Nov 04, 2015Tutor
rjwerth wrote:It seems like a number of people are having the issue since 6.4 who hadn't before. I know historically there have been issues with 6.x and fans from legecy boxes, but I've never had that problem until now. I also didn't see any good solution...did I miss something? Also, everyone else seems to have the error on their CPU fan. Mine is on the case fan. Strange!
Thanks.
RE: I also didn't see any good solution...did I miss something?
Answer: If you did, then so did I. I think our only course of action at this point is to just wait for the next update to be coded / tested and released. I've see a few suggestions here and there. Unfortunately, none of them have worked for me :manfrustrated:
