rjwerth
Oct 28, 2015Luminary
ReadyNAS Pro 6 with 6.4 reporting a status of "Dead"
As the subject says, since putting 6.4 on, the system status is "Dead." Oddly enough, everything seems to be fine except the case fan is not running very much. Temps seem fine so that might be a fe...
- Dec 12, 2015
Thanks for the info, this fixed the issue. I opened up my ReadyNAS Pro 6 and moved the System FAN connector to the unused slot, and the FAN doesn't stop anymore (and I no longer get FAN warnings/errors).
In Step 2 on the page below you can see the slot circled in.
pcmannen
Dec 05, 2015Aspirant
I have the same issue, but my system fan has stopped completely after the upgrade to 6.4. I've also had problems before with previous versions. Can this be a hw issue, maybe use the warranty?
