rjwerth
Oct 28, 2015Luminary
ReadyNAS Pro 6 with 6.4 reporting a status of "Dead"
As the subject says, since putting 6.4 on, the system status is "Dead." Oddly enough, everything seems to be fine except the case fan is not running very much. Temps seem fine so that might be a fe...
- Dec 12, 2015
Thanks for the info, this fixed the issue. I opened up my ReadyNAS Pro 6 and moved the System FAN connector to the unused slot, and the FAN doesn't stop anymore (and I no longer get FAN warnings/errors).
In Step 2 on the page below you can see the slot circled in.
rjwerth
Dec 05, 2015Luminary
Probably not a hardware issue. If you restart your device you will most likely see the fan turn on. That is what I'm seeing anyhow.
Retired_Member
Dec 07, 2015I had the same issue. I opened up my Pro 6 (Business) and move the system fan from the header it was on to the one that was open on the same controller board. I think the open one is call #3. Either way this is the solution that was proposed for those with CPU fan issues.
Running 6.4.1 on Pro 6.
- pcmannenDec 12, 2015Aspirant
- howarddavidpDec 19, 2015Tutor
I am having the sam fan issue, I guess mine started after the 6.4 upgrade.
I don't think it's hardware since on reboot it spins fine...
I moved it to the 2nd fan header, we will see what happens.
David
- walshlinkDec 27, 2015Luminary
Check this thread out...
