rjwerth
Oct 28, 2015Luminary
ReadyNAS Pro 6 with 6.4 reporting a status of "Dead"
As the subject says, since putting 6.4 on, the system status is "Dead." Oddly enough, everything seems to be fine except the case fan is not running very much. Temps seem fine so that might be a fe...
- Dec 12, 2015
Thanks for the info, this fixed the issue. I opened up my ReadyNAS Pro 6 and moved the System FAN connector to the unused slot, and the FAN doesn't stop anymore (and I no longer get FAN warnings/errors).
In Step 2 on the page below you can see the slot circled in.
ATCIS
Oct 28, 2015Tutor
rjwerth wrote:
Anyone else?
Similar problems here. See this post for more details: https://community.netgear.com/t5/Using-your-ReadyNAS/Fan-CPU-in-enclosure-Internal-speed-is-below-threshold-after-FW/td-p/990867
- mdgm-ntgrOct 28, 2015NETGEAR Employee Retired
You may find e.g. this thread useful: https://community.netgear.com/t5/ReadyNAS-Beta-Release/Fan-CPU-Enclosure-Errors-on-Pro-after-upgrading-to-6-4/td-p/990109
- ATCISOct 29, 2015Tutor
mdgm wrote:You may find e.g. this thread useful: https://community.netgear.com/t5/ReadyNAS-Beta-Release/Fan-CPU-Enclosure-Errors-on-Pro-after-upgrading-to-6-4/td-p/990109
Dear mdgm,
Thanks for the suggestion! Unfortunately, the proposed solution in the link you provided did not apply in my case.
Also, I don't know why the URL I inserted above says "Invalid Parameters Specified", but here it is again: https://community.netgear.com/t5/Using-your-ReadyNAS/Fan-CPU-in-enclosure-Internal-speed-is-below-threshold-after-FW/m-p/990867#M94923
EDIT: I think my problem may stem from the early days of OS6 where we had to hack the performance tab with fancontrol and other mods to get that information to display properly. . .
