marioscimone
Mar 29, 2019Aspirant
ReadyNAS Pro 6 with 8TB WD Reds
I had an x-raid made on all 6 hdds, I was running raidiator 4.2.x, I had to shares. I made an upgrade from 4.2.x to 6.9.3 but I forgot to back up one of the two shares, is there any way to recovery t...
- Mar 30, 2019
marioscimone wrote:
Thank you for your clear answer, but I think I didn't started the thread clearly. I had onbord the 6 wd red of 3Tb each with the two shares on it. I made a copy of one share and thinking that was all I did the upgrade loosing all the data in the second share. The right question shuld be: Is there an yway to recover them?
Well, it depends on exactly what you did.
If you removed the 6x3TB drives, installed one or more of the 8 TB drives, and then converted to OS-6, then your original array is intact. If that's the case, you could mount the original array as read-only. Just power down the NAS, remove the new drives (labeling by slot), and reinsert the original disks (ideally in their original order). Then power up. When done backing up the data, power down and reinsert your new disks.
But if you did the conversion with the 6x3TB drives in place, then the conversion process would have reformatted the drives, created a different partition structure, and then installed a new file system on the data volume. If you are really desperate to get the data back, you could try Netgear's data recovery software (or RAID recovery software on a PC), but if you did the conversion with the original disks in place I think the odds are very poor - especially if you have copied back some files to the new data volume.
Mar 30, 2019Guru - Experienced User
marioscimone
Mar 30, 2019Aspirant
Thank you again, unluckily it is the secon scenario you described, I will try with raid recovery but as you said I know I have very very few chance.
I think you answerd and this is the conclusion!
Regards
Mario
